Fixed Gain MOSFET Help!
Discussion in 'Homework Help' started by kauymatty, Apr 28, 2012.
  1. kauymatty
    Apr 28, 2012
    5
    First off I'm a pretty amateur electronics student and I've been trying to design a light organ circuit.
    So, I needed to design a circuit that would amplify the voltage out of a filter and because of what we were taught this year I was advised to use a MOSFET.
    Because my light organ must accept AC music signals I thought I should use a fixed gain MOSFET amplifier, the circuit diagram is attached.
    However the book doesn't seem to give must information about how to calculate Vin and Vout i.e. the gain and how the MOSFET characteristics really come into it (MOSFET is 2N7000)
    Could someone please explain how to work everything out?
    Thankyou in advance.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    What is your input voltage range? And how much gain you want?
    What frequency range you want to amplify? And what is the load? Your supply voltage? etc...
  3. kauymatty
    Apr 28, 2012
    5
    Well input voltage range is probably between 0 - 3V, a gain of 2. The entire circuit will have 4 amps, 1 from the audio input, ranges 30-16kHz, then 3 in total after filters e.g. 1 after a bass filter 90-5000, mid-tone 5000-10000, treble 10000-16000.
    I want to use a supply voltage of 15V-0V, the output of each of the filter amps will go to probably 2 LEDs, for now, parallel, and a 330ohm resistor
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    First we need to use data sheet to find K - factor
    http://www.onsemi.com/pub_link/Collateral/2N7000-D.PDF
    Form figure 1
    K = 0.39A/ ( 5V - 1.9V)^2 = 0.04058 = 40.58m
    So we need to find Rd and Rs
    Id = (Vcc - Vgs) / (Rd + Rs)
    Vgs=Vt+\sqr{\frac{Id }{K}}
    so we get
    Rd + Rs = \frac{(Vcc - (Vt+\sqr{\frac{Id }{K}}) )}{Id}
    For Id = 5mA
    Rd + Rs = 2549.8 ≈ 2.55K
    And to get the gain equal to 2
    Av = Rd / ( 1/gm + Rs)
    gm = 2 * √(Id * K) = 28.5mS
    So in our case
    Av ≈ Rd/Rs = 2
    and Rd+Rs = 2.55K
    So we solve for Rd and Rs
    Rd = 1.7KΩ ; Rs = 850Ω
    But to improve freedom in choosing the operating point it is better to use voltage divider
    To archive high output voltage swing Vds must be equal to 0.5Vcc = 7.5V
    So we choose Rd = 1K and Rs= 470Ω
    Au = 1K/0.47K = 2.1V/V
    Now we chose Id current
    Vds = 7.5V
    Id = ( 15V - 7.5V) / ( 1.47K) = 5.1mA
    Now we select R1 and R2
    Voltage at the gate is equal to
    Vg = Id * Rs + Vgs = 5.1mA * 470Ω + Vgs
    Vgs=Vt+\sqr{\frac{Id }{K}}=1.9V +\sqr{\frac{5.1mA }{40.50m}} = 2.25V
    so the gate voltage
    Vg = Id * Rs + Vgs = 5.1mA * 470Ω + 2.25 = 4.647V
    R2 = Vg/Idz
    R1 = ( Vcc - Vg) /Idz
    Idz = We can choose any value but we need too remember that R2 and R1 determine the input resistance of our amplifier.
    But I can also choose R1 = 470K for example
    And then find R2
    the new Idz current
    Idz = (15V - 4.647V)/ 470k ≈ 22μA
    R2 = 4.647V/22uA ≈ 211K ≈ 200k
    But in reality you will be forced to pick R2 on the bench.
    In order to get Vds voltages equal to 7.5V
    As for capacitor use this equation
    C = 0.16/(F * R)
    R - resistance seen from the capacitor terminals
    F - the frequencies you wanted to pass
    If you wanted to pass frequencies higher than 30Hz then
    C1 > 0.16/( 30Hz * R1||R2) = 39nF
    kauymatty likes this.
  5. kauymatty
    Apr 28, 2012
    5
    Wow, a lot more than I thought it would be. Thanks a lot for all your help! Hopefully my final project will work now :)
  6. kauymatty
    Apr 28, 2012
    5
    Just quickly, where did you get 5V from in the figure 1 calculation and what is Av?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    From the data sheet
    To find K parameter we need Vt = Vgs(th)
    So I pick average Vt value
    Vt_max = 3V and Vt_min = 0.8V
    Vt_ave = (3V + 0.8V)/2 = 3.8V/2 = 1.9V
    I also need Id current for a given Vgs voltage
    So I use figure 1 or figure 2 to read the Id for a given Vgs.
    I pick randomly Vgs = 5V. And I use figure 1 to find Id current for Vgs = 5V
    In real life we a force to forced to measure Vt and Id to find K factor.
    Because MOSFET show great process spreader. For example on Vgs(th) = Vt = 0.8V...3V So only real measurement can give you exact K value.
    To find K factor for the MOSFET in the lab bench all you need is this simply circuit:
    The symbol on the top represents the constant current source.
    And for this circuit Vds = Vgs
    So now we need to find Vgs for given Id current.
    And the only thing that we need to change in this circuit is to increase the value of a constant current source.
    For example for Id = 0.1mA we read Vgs = Vt
    And for Id = 10mA we read Vgs in linear region.
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Oh I forgot about Av
    Av - is a voltage gain
    Av = Vout/Vin = Rd / ( 1/gm + Rs)
  9. kauymatty
    Apr 28, 2012
    5
    Well thankyou for all of your help, this all makes a lot more sense now. Much better than the book I have. Thanks once again.
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    In reality we don't calculated K factor.
    We simply use a voltage divider plus a potentiometer to select the right bias point.
    See the example diagram
    The voltage gain is set by
    Av = ( R3 + R4 + R5)/ R6 = 45/15 = 3V/V
    And we use pot PR to set drain voltage equal to 7.5V (0.5Vcc)
    And when we pick Rd resistor we use this rule of thumb (but not always).
    Rd = 0.1* Rload
    and
    Id = 0.5Vcc/Rd
    Rs = Rd/Av
