And according to you if you had one 108 degree day then for the rest of the year returned to your balmy minus 5 that would be the hottest year on record?It's the when, where and how in reality that determines whether it's of significance or not.
Does raising the temperature of your garage that's on the far side of your yard in the middle of the night make your house warmer in the middle of the day?
Statistically more heat energy was pumped into your property in that 24 hour time line so by the numbers it should make a significant difference right?
According to you statistically by the numbers warmer is warmer and that's what matters, right?
