Hi everybody,
Just found this forum and will enjoy browsing the help available here.
I'm renovating a Hymer motorhome...about 75% done. One of the jobs involves fitting a new step (a Thule 12V Double Step.)I also ordered the relay kit which enables the step to automatically retract if the user has forgotten to do, before moving off. I think I understand the circuit diagram, but as the step was expensive (over £300), I want to get the install correct.
As far as I understand, I need to locate the accessory position on the ignition, then run a wire from there to the relay 85 connector. As the wire also feeds connector 87, can I just 'piggy-back' the wire from 85 to 87. The rest of the circuit I think I understand, it was how to modify the diagram taking the buzzer out of the equation.
I was thinking of running the wire from the ignition to the step position and fitting the relay and capacitor near the step position which is towards the rear of the motorhome.
https://www.flickr.com/photos/33383402@N06/28910679535/in/dateposted-public/
Thanks for any help you can give.
Al
Al
