Fitness functions error
Discussion in 'Programmer's Corner' started by shegmite, Mar 18, 2014.
  1. shegmite
    Apr 5, 2013
    I tried to run this function in matlab to minimize measured data and simulation from equations and I got this message: input argument is undefined ??? Can anyone tell what the correct syntax is.
    Code ( (Unknown Language)):
    1.
    2. [FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff]
    3. function[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2] Ap = insertionlossnew(x)
    4. L1 = 3;
    5. x(1)=Zcd1;
    6. L2 = 24;
    7. x(2)=Zcb;
    8. L3=3;
    9. x(3)=Zcd2;
    10. Ap=zeros(1,15);
    11. [/SIZE][/FONT][/SIZE][/FONT][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff]for[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2] v =[1 4 8 10 16 20 25 31.25 62.5 100 200 250 300 400 500];
    12. Ap = (v*((L1)*(Zcd1)+(L2)*(Zcb)+(L3)*(Zcd2)));
    13. Am=[20.3 23.4 24.6 25.3 23.4 26.4 27.5 22.9 23.7 29.8 31.3 32.8 27.9 25.8 35.6];
    14. [/SIZE][/FONT][/SIZE][/FONT][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff]end
    15. [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2]Y1=sqrt(sum(Ap-Am)^2);
    16. Y2=mean(Am);
    17. Y3=sqrt(sum(Am-Y2)^2);
    18. Y4=Y1/Y3;
    19. Y=(1-Y4)*100;[/SIZE][/FONT][/SIZE][/FONT]
    20.  [FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2]disp(Y);
    21.
    22. [/SIZE][/FONT][/SIZE][/FONT]
    23.
  2. ActivePower
    Member
    Mar 15, 2012
    155
    23
    I'm not really sure that you understand MATLAB functions. For syntax queries, built-in MATLAB Help is a great resource. As is their website. As is Google.
    MATLAB functions, like their counterparts in many other languages, require you to pass a list of input arguments which they process to provide a list of outputs.
    The error you're getting means that you're not passing any value for the function to act upon.
    Skimming though your code listing - your function takes a single input, x (a vector perhaps), to spit out a number. Variables Zcb1, Zcb and Zcd2 don't get a value anywhere (remember assignment works right to left). Yet you're assigning their values to elements located in x - this will certainly fetch you an error. I guess what you intended to do was this:
    1. Zcd1 = x(1)
    Also (and I don't know whether you intended it to do this), your function's return value is the vector Ap.
    HTH.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Maybe it would be a good idea to learn how to crawl before you try to run a marathon.
  4. shegmite
    Apr 5, 2013
    I have just done as you suggested in your last message. I hope am right ?
    function Ap = insertionlossnew(x)
    L1 = 3;
    Zcd1=x(1);
    L2 = 24;
    Zcb=x(2);
    L3=3;
    Zcd2=x(3);
    Ap=zeros(1,15);
    for v =[1 4 8 10 16 20 25 31.25 62.5 100 200 250 300 400 500];
    end
    Y2=mean(Am);
    Y4=Y1/Y3;
    Y=(1-Y4)*100;
    disp(Y);
  5. ActivePower
    Member
    Mar 15, 2012
    155
    23
    The assignments look correct. I'm not sure how you're calling this function from your shell/main script though, as that was the cause of your original error. Why don't you try it and see for yourself? That'll give you a better idea.
    PS: Use the Code tags (the ones indicated by the pound ('#') sign), when posting code. It'll help you format your post better and make it more readable for others.
