But you save as a custom component correct? So for example, I already have a number of diodes placed. I want to change the pad size of all of them. I need to first edit as you described, then replace all of the components?To edit an existing component in ExpressPCB :
- Select the component you want to edit.
- Click on the "Component" menu.
- Select "Ungroup PCB Component".
- Once you have done this, unselect the item, (by clicking somewhere else on the screen...)
- double click the pad you want to edit, a window will pop up where you can change the size of the pad and drill hole.
- make the changes you want......
- once you are done editing, select the whole component again,
- click on the component menu again
- select "Group to make component"
- then you can save the component under your favorite components....
You can make then any size you want, as long as you leave enough room between pads so you don't easily bridge the solder across 2 pads...
