First Order Circuits
Discussion in 'Homework Help' started by newzed, Jan 11, 2012.
  1. newzed
    Jan 11, 2012
    16
    Hello Everyone!
    I have those two exercises from my textbook involving First Order Circuits with Capacitors and Inductors..
    Now, in the first one the exercises wants a v(t) that is not the capacitor one..
    For t>0 isn't the whole right part after the switch going away? So isn't it
    v∞(t) = 6 ?
    But v for t<0?
    In the second one the inductor behaves like a short circuit to dc...
    for t<0 isn't i=0 ?
    for t>0 isn't it 0 again?
    I'm kinda confused...
    thanks for your help :)
  2. Jony130
    Feb 17, 2009
    3,991
    1,115
    After the switch is close the right resistor R will be shorted by the switch.
    So yes at t=∞ v = 6V. But at t(0) voltage will we equal to 3V.
    what is your guess
    It seems to me that you are right
  3. newzed
    Jan 11, 2012
    16
    Answers in the book are in the file attached
    Can you explain me why is it 3 at t(0) ?
    And apparently it's not 0 for the second exercise..
  4. Jony130
    Feb 17, 2009
    3,991
    1,115
    Before the switch is close t < 0 the voltage V1 = 6V and V2 = 3V
    V1 = Eo*R/(2R) = 1/2Eo = 0.5Eo = 6V
    V2 = E1 * R/(3R+R) = E1 * 1/4 = 0.25E1 = 3V
    So the capacitor is charged to Vc = V1 - V2
    At times equal t = 0 ( when the switch is close ) V2 = 0V (short by a switch) And the capacitor act lice a Voltage source at time t = 0.
    So V1 must be equal Vc. And capacitor start charging to reach at t = ∞ 6V.
    Yes, your book is right. I made the mistake.
    At time t = ∞ the switch is in close position, so current will be flow through the right resistor. I = E2/R = 5A
  5. newzed
    Jan 11, 2012
    16
    ok i'm starting to understand... But why does Capacitor acts like voltage source?
  6. Jony130
    Feb 17, 2009
    3,991
    1,115
    At time equal t = 0 voltage across capacitor is equal to 3V. So when we close the switch we connect already charged capacitor parallel to left resistor. And capacitor force the V1 voltage to drop from 6V to 3V. At that moment the circuit behaves very similarity to the circuit in which we replace the capacitor with voltage source.
