first order circuit
Discussion in 'Homework Help' started by progrocklover, Feb 17, 2011.
  1. progrocklover
    Jan 31, 2011
    My question is: for t>0, Should I treat the depentent 4io source as zero since the current io indicated on the figure is zero ?
    Any help is appreicated.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think so. That would nullify the current source and leave only the middle voltage source to power the circuit after the switch is flipped.
  3. jegues
    Sep 13, 2010
    735
    43
    Yes, make sure you replace it by a short, because its going to effectively short out the rightmost portion of your circuit.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Jegues has corrected me. I mistook the dependant source for a current one, while it is a voltage source. Shorting it is mandatory.
