First designed schematic, please check
Discussion in 'The Projects Forum' started by Adamf001, Aug 6, 2012.
  1. Adamf001
    Sep 5, 2011
    67
    Hello again AAC,
    taking some of your guys advice I have finally designed a power supply for a few projects etc...
    The circuit involves using the voltage adjuster LM317 and LM337
    could some of the experienced designers just give my schematic a once over, make sure there is no obvious faults. and as another question, do I need that Capacitor that I have circled? if so why?
    (Sorry for the poor scanning quality)(both attachments are the same)
    I designed the circuit by combining the best bits of a couple of a designs
  2. #12
    Nov 30, 2010
    16,703
    7,338
    Your chip usage is good but your transformer connections have a fault.
  3. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Your trying to split a single transformer to get both positive and negative outputs. You can't do that (with or without C1). You need a center taped transformer to get both plus and minus outputs. Or a second transformer.
    The 10 uF on the ADJ terminals may slow the response when you adjust the pots. I would leave them out.
    Those pots will be drawing up to 10 mA when nearing zero volts, so make sure they can handle that.
  4. #12
    Nov 30, 2010
    16,703
    7,338
    You can't get there with that transformer. Try this.
  5. Adamf001
    Sep 5, 2011
    67
    ok, I understand that so would I be able to place a secondary transformer in place of C1?
    and how would I get a negative supply from the secondary transformer, because I think I need a negative supply being suplied to the LM337? or not?
  6. Adamf001
    Sep 5, 2011
    67
    I think your Idea would be better than using two transformers, and I see how you can get a negative supply, thanks 12...
    but just for arguments sake I'd like to know how I'd do this with two transformers??
  7. #12
    Nov 30, 2010
    16,703
    7,338
    Just use the secondary winding of the second transformer as a continuation of the secondary on the first transformer. The point where you attach them together becomes the "center tap".
    Adamf001 likes this.
