first circuit
ttyler333
Joined Aug 11, 2010
So this is my first circuit, i know its not perfect but i plan on making it perfect. How would i go about limiting each motors energy use to only 3 volts? How would i also limit the amount of electricity the LED's will receive. Would that setup also be good to allow the solar panel to charge the batteries?
i would also like to impliment an rc controller, one that'd allow the motor to be controlled. You know, so it does not run away. Curious though how i would go about adding that to it.
http://img375.imageshack.us/img375/80/circuit1.jpg <-- link to fullsized image above.
bradstormer
Joined Aug 6, 2010
65
using resisters you can easily limit the voltage through your circuit. using ohms law one can calculate the voltage around your circuit.
now your photoresister on its own wont really work as a switch to turn on your LED's. you could use a transistor circuit. a transistor is like an electronic valve, which when used in a certain configuration can work like a switch.
failing that you could use a potential divider circuit.
i suggest learning to crawl before you walk, learn the basics of voltage and current, experiment with basic battery and resister circuits to get different voltage drops and then try your circuit. even with a basic knowledge you can create great circuits!!
and enjoy!!
Wendy
Joined Mar 24, 2008
23,415
A LDR (aka photocell, or electric eye) will not be able to turn on the electricity by itself. They tend to vary between 100Ω to 1MΩ. 100Ω is still to large to be considered an on switch.
LDR
