First, let me thank those who helped me get this far. You can only read a book, not ask it questions, so thank you AAC for your help.
On to the program. This is my first C program, so I'd like to know if anyone sees any errors, or if you have suggestions as to how I could have written the code more efficiently, I'd certainly be interested in that as well. This is a very simple program my first time out that just uses a global variable, some time delays, and a couple of if statements.
One of my first projects when I was learning Assembly was what seems to be a favorite for projects and for beginners; a Traffic Signal. I figured, why not make that my first C project too. Attached to this thread is a flow chart which illustrates what the program does, and a schematic for the hardware. I put it together on my breadboard and everything is working quite well, though I noticed my time delays seem to be off a bit. Maybe the clock isn't running at my intended speed or I did something else wrong, but the program seems to be running a bit fast. Anyways, on to the code!
Thanks for the feedback! EDIT: I just saw on my .pdf that I have the supply voltage listed as 12V. This is incorrect for this project and should be listed as a 9V battery, my bad.
Rich (BB code):
// 6-LIGHT, 4-WAY INTERSECTION TRAFFIC CONTROL SIGNAL
// JAN-14-2011
// PIC16F628A
// HIGH-TECH C COMPILER, MPLAB IDE
// THIS PROGRAM IS FOR A 6-LIGHT INTERSECTION TRAFFIC CONTROL
// SIGNAL WHERE BOTH THE MAIN TRAFFIC LANES (MAIN) AND SECONDARY
// TRAFFIC LANES (SDRY) HAVE A SINGLE SET OF RED, YELLOW, GREEN
// LIGHTS WHICH WILL CYCLE TO SAFELY CONTROL TRAFFIC WHILE
// OPERATED IN THE NORMAL CYCLE. THE SIGNAL ALSO HAS 2 NIGHT-
// MODE CYCLES WHERE MAIN TRAFFIC LANES RECEIVE A FLASHING YELLOW
// SIGNAL WHILE SECONDARY TRAFFIC LANES RECEIVE A FLASHING RED
// SIGNAL, OR ALL TRAFFIC LANES RECEIVE A FLASHING RED SIGNAL.
// SELECTION OF EITHER OF THESE NIGHT-MODE CYCLES IS DEPENDENT ON
// THE POSITION OF A SINGLE ON-OFF-ON SWITCH WHICH WILL INPUT
// HIGH TO RA0 OR RA1. WHEN BOTH INPUTS ARE LOW, NORMAL CYCLE
// OPERATION RESULTS. THE SIGNAL IS PROGRAMMED TO NEVER ALLOW AN
// UNSAFE SIGNAL CONDITION, THEREFORE, TRANSITION FROM NORMAL
// OPERATION TO A NIGHT-MODE CYCLE OR VISE-VERSA IS NOT
// INSTANTANEOUS, AND WILL OCCUR ONLY AT THE PROGRAMMED SAFE
// POINT.
// CONFIGURATION
#include <htc.h>
#define _XTAL_FREQ 48000
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & BORDIS & LVPDIS & UNPROTECT & UNPROTECT);
// INTERNAL 48KHz CLOCK, PWRT, NO PROTECTION
// GLOBAL VARIABLES
unsigned char count;
void main()
OSCF=0; //LOW POWER 48KHZ INTOSC
CMCON=0x07; //COMPARATORS OFF
TRISA=0x03; //RA0 AND RA1 INPUT, OTHERS OUTPUT
TRISB=0; //ALL PORT B ARE OUTPUTS
while(1)
while (RA0==1) //WHILE INPUT AT RA0, NMRR
PORTB=0x08; //RB3 ON, SECONDARY RED, ALL OTHERS OFF
__delay_ms(500);
PORTB=0x01; //RB0 ON, MAIN RED, ALL OTHERS OFF
__delay_ms(500);
while (RA1==1) //WHILE INPUT AT RA1, NMRY
__delay_ms(500);
PORTB=0x02; //RB1 ON, MAIN YELLOW, ALL OTHERS OFF
__delay_ms(500);
if ((RA0!=1)&&(RA1!=1)) //RA0 AND RA1 NO INPUT
PORTB=0x09; //RB0 ON, RB3 ON, MAIN RED, SDRY RED
for (count=0; count<3; count++)
__delay_ms(1000); //LOOP 1 SECOND DELAY 3 TIMES, 3-SECOND DELAY
PORTB=0x0C; //RB2 ON, RB3 ON, MAIN GREEN, SDRY RED
for (count=0; count<20; count++)
__delay_ms(1000); //LOOP 1 SECOND DELAY 20 TIMES, 20-SECOND DELAY
PORTB=0x0A; //RB1 ON, RB3 ON, MAIN YELLOW, SDRY RED
for (count=0; count<4; count++)
__delay_ms(1000); //LOOP 1 SECOND DELAY 4 TIMES, 4-SECOND DELAY
PORTB=0x21; //RB0 ON, RB5 ON, MAIN RED, SDRY GREEN
for (count=0; count<15; count++)
__delay_ms(1000); //LOOP 1 SECOND DELAY 15 TIMES, 15-SECOND DELAY
PORTB=0x11; //RB0 ON, RB4 ON, MAIN RED, SDRY YELLOW
