First Blog Entry
Discussion in 'Off-Topic' started by ActivePower, Jan 8, 2014.
  1. ActivePower
    Mar 15, 2012
    155
    23
    Hello everyone!
    I just posted a blog entry - my first here at AAC. I've been meaning to post this for some time now but couldn't. Turns out a single waking hour after midnight was all I needed.
    Anyways, I hope it is useful and any constructive suggestions are welcome as always.
    DerStrom8, strantor and JohnInTX like this.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    It was a pleasant read. Thanks for staying in version 2.7.
    It reads like a light, short multi-page tease for someone who wants to know what Python is about.
    I hope this was your intention.
  3. ActivePower
    Mar 15, 2012
    155
    23
    Why, it was indeed my intention. Thanks for reading. I'll try and post the next entry soon.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    It's a decent teaser of learning Python.
    I would mention it being an interpreted language as another difference from C, but that may just be me...
    Also, there is an open-source alternative to MATLAB in GNU Octave, which strives to fully implement MATLAB functionality with few deviations.
    Overall, a good read.
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Nice work so far! I had considered learning Python some time ago but I ended up sticking with C++ and Java, since they tend to be most common in the area where I live and work. I will definitely be following your blog though.
    Many thanks!
    Matt
  6. ActivePower
    Mar 15, 2012
    155
    23
    I'm sorry I kind of messed up in the last entry when I said that Python is a weakly typed language. Turns out I was indeed wrong with my understanding of what that term implied. I made what is apparently a common mistake of wrongly judging Python to be a weakly-typed language based on its leniency towards variable manipulations forgetting many basics things in the process.
    I have rectified the error in the entry since and added a shoddy explanation to it. I chose to include the incorrect version in the post nonetheless if only for educating anyone else who might make a similar mistake.
    (Btw I have since then posted the next article)
    Once again, my apologies for the error.
  7. Brownout
    Jan 10, 2012
    2,375
    998
    I use a combination of shell programming (csh) sed, awk & Perl to manage my linux projects.
    I've never found a comparable solution to windows projects (don't care much for running gnu tools under windows) Might python do what I want? Creating, searching, copying directories, text generation, text to database conversion etc.
  8. djsfantasi
    Apr 11, 2010
    2,911
    881
    Which version of Windows do you want to do this on? Windows command scripts can do much of the examples you quoted. These are ".cmd" or ".bat" files. Give me some specific requirement and I'll see if I can write an example.
    I once wrote a script to access a series of web sites, time it's response and send an email if the sites were having problems. The only sticking point might be text to database conversion, but it depends.
  9. ActivePower
    Mar 15, 2012
    155
    23
    @Brownout: I occasionally use Bash scripts under Linux to automate system tasks too. For some reason, I never considered Python for the same job. Under Windows, you could use Batch scripts as @djfantasi said.
    Python does support quite a bit of OS related manipulation through its os module. I've never tried using it for this purpose though, so if you could give me something I'll try and see if I can work on it in Python.
