Firing circuit for triac
Discussion in 'The Projects Forum' started by snp2411, Mar 11, 2009.
  1. snp2411
    Mar 11, 2009
    11
    How do we convert the analog voltage to firing angle(proportional to the voltage)for triggering the triac....
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Compare a triangle/sawtooth voltage that is synchon to the AC with the DC you want to translate into the fire angle.
    Greetings,
    Bertus
  3. snp2411
    Mar 11, 2009
    11
    i dint get you...in my project i convert the digital output of a microcontroller into analog voltage and with this i need to trigger the triac...this is used to improve the efficiency of a induction motor...:(
  4. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    You can make a sawtooth generator that is resetted by the zerocrossing of the AC voltage.
    This sawtooth voltage can be the input of one side of a comparator.
    The other input of the comparator is your DC voltage.
    The output of the comparator will give the fire angle,
    Greetings,
    Bertus
  5. snp2411
    Mar 11, 2009
    11
    sir can u design the circuit for it and post it to me...
  6. snp2411
    Mar 11, 2009
    11
    or do we have any IC's to do that or any websites that has this circuit design...
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  8. snp2411
    Mar 11, 2009
    11
    thank you..but i need circuits which produces firing angle...which inturn improves the efficiency of the motor...can somebody help me in designing the firing circuit as in the block diagram...
  9. onlyvinod56
    Oct 14, 2008
    362
    Hi
    i think i can help u here right now... if u give the details of ur digital outputs of MC..
    What is the supply frequency?
  10. onlyvinod56
    Oct 14, 2008
    362
    Use a zero crossing detector (for example MCT2E).
    The pulses from ZCD can be used as interrupt signals for ur MC.
    Suppose, If ur MC is giving a 3ms pulse at an instant, that cannot be directly given to the triac. Why Bcoz, if u give the 3ms pulse to triac, it conducts from 0 to 3ms (consider a 50Hz supply. time period is 20ms. half cycle period is 10ms). But if u see the operation of an AC voltage controller, when u give a pulse to the triac, it starts conducting from the instant at which the pulse is given, to natural zero point(180 degrees or 10ms here).
    But your controller makes the triac to conduct from 0ms to 3ms. As usual the triac will be turned off at natural zero crossing(180 deg or 10ms). i.e., the triac is conducting for 0 - 180 and 180 - 360.
    So u r not at all controlling the voltage.
    So. Use a transistor logic to modify the pulse from 3ms to 10ms.
    here iam attaching a small figure. check this out. If u dont get any idea, i'll send u a detailed one later
  11. snp2411
    Mar 11, 2009
    11
    thank you....i am getting some idea..can u post the detailed circuit...
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    What phase angle are the Triacs supposed to be turned on at?
    Phase to Time equations:
    Degrees:
    \Delta t=\frac{\theta}{2 \cdot \pi \cdot f}
    \theta = 2\cdot \pi \cdot f \cdot \Delta t
    Radians:
    Angular Velocity = ω = 2πf
    \Delta t=\frac{\phi}{\omega}
    \phi = \omega \cdot \Delta t
    Voltage at Angle:
    V=V_{Pk}\cdot sin(\theta) = \sqrt{2} \cdot V_{\footnotesize{RMS}} \cdot sin(\theta)
  13. onlyvinod56
    Oct 14, 2008
    362
    what is the supply voltage and supply frequency?
    I will give u the complete idea
  14. snp2411
    Mar 11, 2009
    11
    the supply voltage is 415v and 50hz
  15. snp2411
    Mar 11, 2009
    11
    for example, suppose the voltage to the firing circuit ranges from 0-5v then the firing angle should vary between 0-180deg...
