Fire fighting robot without microcontroller
Discussion in 'Homework Help' started by MohamedSaa3d, Apr 30, 2014.
  1. MohamedSaa3d
    Feb 16, 2014
    13
    hello , i have a task that i should to do
    making a fire fighting robot without microcontroller -_-
    i need to know how can i connect sensors to logic gates and how can i convert the analog ouput to digital to use it in the gates
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    What sensors? What requirements?
    In general, one could use a comparator to convert analog to digital.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm not sure you can implement this functionality in any meaningful way, but since you have defined no actual requirements it is hard to speculate on results. Is there some particular reason for your desire to avoid a microcontroller?
  5. djsfantasi
    Apr 11, 2010
    2,911
    881
    Start with a block diagram of what the robot needs to do. I assume that the first step is to provide a means of locomotion to search for and navigate to the fire. Another step is fine control to get close enough to the fire. Then there must be a method of triggering whatever fire suppression method you are using...
    Can you provide more detail as to the arena in which this robot is going to operate? What is required by this assignment? What do you have control over (i.e., is the fire suppression method specified or can you choose)?
    There is a variety of sensors that you can use for each function. For example, if you research IR sensors, you may find them useful.
    Research robots, too. You may find that simple line following robots use logic that you also may find useful. This is a popular contest/assignment so I know there are resources you can find.
    As to your original questions, connecting sensors to logic gates and converting analog to digital, it all depends on the sensor. Light dependent resistors change their resistance. They can be used to provide a variable voltage which can further be converted with a comparator. IR receivers output a voltage and often can be directly interfaced to digital logic. Also, minor poiint, but you state the assignment says you cannot use a microcontroller, but nothing about requiring digital logic. Is this correct?
    absf and Papabravo like this.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I was not sure if this was a school assignment or an open ended query. If it is a school assignment and the only requirement is to avoid a microcontroller, then I need to ask if a complex FPGA would be a fair approach. We really need more details on requirements in order to help you on this one.
  7. Inquisitive
    Nov 12, 2011
    8
    9
    Let me put forth few points to ponder. What types of fires will it deal with. Structural fires? Chemical fires? Vehicle fires? What about an electrical fire? What method of fire suppression will it use? Chemical? Water? Fires come in different classifications. Not all suppressant chemicals will work on all jobs. Will it determine the proper fire class? Class A, B, C, D or K? Which combinations will you use? Each fire classification must be handled differently. If using chemicals how strong is the device, can it carry 20 lbs? 50lbs of suppressant. Will it use foam? If this device tows a charged line can it withstand the physical forces? How big will the hose be? The larger the line the the more counter force/weight is needed to stablize the robot.Some chemicals remove oxygen such as Halon as their approach to extinguishment, if a human is nearby the robot could possibly kill a human if the wrong choice is made.
    If it gets too close to its intended work radiant heat will destroy the device. If any plastics are used they will melt. How will it determine the proper location to attack the fire? Will it use European firefighting methods or will it use North American methods. Both have benefits and costs to the methodology.
    Just a few thoughts.
    There is more to firefighting than meets the eye.
    absf likes this.
  8. djsfantasi
    Apr 11, 2010
    2,911
    881
    Inquisitive - while very informative, I suspect that this may be beyond the assignment the OP has been tasked with. IMHO
    I also note that the OP has not responded for a week… Perhaps this is another "drive by" posting.
  9. MohamedSaa3d
    Feb 16, 2014
    13
    am sorry for delay in replay because of the study :)
    here is the details
    and in this competition
    Important rules:
    1. The system is to operate using digital logic circuits (and make use of some analogue
    interfaces) in order to fulfill the task.
    2. The robot has to be able to avoid collision with any wall.
    3. No microprocessors nor microcontrollers are to be used. -_-
    4. No remote control or keypad are to be used.
  10. crutschow
    Mar 14, 2008
    13,515
    3,386
    Did you not look at this reference I previously posted? :confused:
  11. MohamedSaa3d
    Feb 16, 2014
    13
  12. MohamedSaa3d
    Feb 16, 2014
    13
    yes i read about 38KHz IR Infrared Transmitter Module
