Finite State Machine Help
Discussion in 'Homework Help' started by testing12, Nov 10, 2011.
  1. testing12
    Jan 30, 2011
    80
    Hello Again,
    Im having an issue working with a FSM with 2 inputs, D and N in this case. I created my table but do not know how to map the inputs of the d-type Flip flop to D, N and the current states (y2 and y1). Please see below. The solution manual has the inputs of the flip-flops in terms of D, N and the states which leads me to confusion.
    EDIT: I forgot to mention the given state diagram is in the bottom right corner.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    testing12 likes this.
  3. testing12
    Jan 30, 2011
    80
    Thank you, it seems the AAC guide uses a different approach to making the state table then my text. To avoid confusing myself I'll email my professor this question as he did a similar problem in class. Thank you for your reply georacer.
