Fingerprint module
Discussion in 'The Projects Forum' started by MarcoRamos, Jan 7, 2014.
  1. MarcoRamos
    Dec 12, 2013
    7
  2. elec_mech
    Nov 12, 2008
    1,513
    193
    I assume you already have some type of electronic lock?
    Assuming this isn't to protect a high security area, why not use one of these? This can also be found here with free shipping if you're in the U.S. and have an Amazon Prime account. Runs $50 USD vs. $228 USD.
    Yes. What is your level of experience with electronics and programming?
    Referring to the module I suggested above, it appears you simply send a command from the microcontroller and have the user press his or her finger to the sensor three times. You could simply add a button to the hardware so when pressed it sends the add a user command. Being you might not want any yahoo to add users willy nilly, you may instead opt to add a keypad so a code must be entered to allow a new user to be added.
    MarcoRamos likes this.
  3. MarcoRamos
    Dec 12, 2013
    7
    Thanks for the help :) I have some experience with microcontroler PIC so that fingerprint scanner is a good choice. But tell me, I have make some research and I cant kill my doubt yet, I see a lot of fingerprint reader modules, similar to your and mine, all need the microcontroler? Best regards!
  4. mcgyvr
    Oct 15, 2009
    4,798
    979
  5. MarcoRamos
    Dec 12, 2013
    7
    Thanks that was my big doubt, thanks for all the help!
