finding value of emitter bias resistor
Discussion in 'Electronics Resources' started by thampiverghese, Mar 11, 2014.
  1. thampiverghese
    Mar 10, 2014
    I am trying to repair an Ecolite.I found that it has a MMBTA42 as oscillator for wireless.The grounding resistor is open.How do I find the value to replace it?No info available on circuit. It is a 276 V system.When I arbitrarily substituted a 10K resistor it worked . But how do I know that is the correct value? Please help.Thanks.
  2. crutschow
    Mar 14, 2008
    13,523
    3,390
    Unless you have a circuit schematic it would be difficult to know what the correct value is.
  3. thampiverghese
    Mar 10, 2014
    Thanks.There is no info available on the schematic.All components are SMT. Color coding or values are not written on resistors.ID of transistors,diodes and capacitors are available. This is almost like reverse engineering.
  4. thampiverghese
    Mar 10, 2014
    Here is the circuit.I am trying to find the value of R3.
