Finding unknown values in a circuit
labhelp
Joined Jan 28, 2010
28
In my lab we were given 3 black boxes and a sheet with 3 different circuits(shown in the attached pdf on page 3). We were then told to find out which box went with which circuit then find the values of all of the components. We found the transfer functions for each circuit then ran a voltage sweep on the actual circuit to see what the graph would do. We figured out which box went with which circuit and also figured out the values of the resistors. We are stuck on how to figure out the value of the capacitors. We have a lot of equipment available like a Oscilloscope, DMM, waveform generator, and a DC power supply.
Can I get some advice on how i can obtain the capacitances for each of the circuits? thanks in advance.
beenthere
Joined Apr 20, 2004
15,819
Pick two frequencies to apply to the box input. Calculate Xc for those frequencies, and use that to solve the network and get the magnitude of the output for both situations. The difference between the two will let you determine the size of the capacitor.
