Finding the values
Discussion in 'General Electronics Chat' started by superway, Jun 30, 2010.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    I have a circuit below with standard yellow LED, transformer, Resistor and Diode. Please help me to find the correct value of resistor and Diode.
    Please see a drawing.
    Ken
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Reposting your image to make it a bit more legible.
    You are over complicating this a bit, basically you have a simple transformer feeding the diode circuit. Figure the RMS value and plug in the numbers for 20ma. Less current is better, since your peak current surge is significant. Personally I would have put the conventional diode is parallel instead of series with the LED, but that is a matter of taste.
