Finding the resistance between the drain and the source - transistors
Discussion in 'Homework Help' started by trappy, Mar 27, 2008.
  1. trappy
    Mar 27, 2008
    7
    Hi guys ,
    My first post so please go easy - what a good site !
    Right i have a question im struggling with .
    I have a transistor (type not known) with a resistor conected to the emitter,
    the base of the transistor is connected to the source which is 5 volts and the collector is connected to ground.
    im told Vt is 1 volt and K = 0.5 mAVsquared Vd is 0.1volt
    im asked to calculate the effective resistance between the drain and the source?
    what does this mean ? are they asking for the current through the resistor ?
    Any formulaes / solutions would be greatly appreciated.
    thanks in advance
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Source and drain implies FET; collector, emitter and base implies BJT. Which one are we looking at here?
    Do you have a circuit diagram? That might help clear things up.
    Dave
  3. trappy
    Mar 27, 2008
    7
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That's a misdrawn FET.
    With 4.9 volts dropped across the resistor and .1 volt across the FET, the FET resistance is 49x that of the resistor.
  5. trappy
    Mar 27, 2008
    7
    thats the only diagram given in the question i have , hence my confusion !?
  6. veritas
    Feb 7, 2008
    167
    Why do you think that is a misdrawn FET, beenthere? I've seen that symbol used for it dozens of times in my classes.
    (sorry to post somewhat off-topic)
  7. veritas
    Feb 7, 2008
    167
    to clarify for trappy, since you have Vd, you can solve this just as though it were a voltage divider with two resistors => Vd = Vcc * Re / (Re + Rd), assuming that Re is the effective resistance of transistor from source to drain.
  8. JoeJester
    Apr 26, 2005
    3,390
    1,211
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The nMOSFET operating in the triode region (which it it in this example) the resistance is given by:
    r_{ds=\left[k(W/L)(V_{gs}-V_{t})\right]
    This would calculate the effective resistance as a function of Vgs (which is the controlling parameter in the triode region. Given the information you have (you are not given the transistor dimensions although you can calculate it), the voltage divider explanation given above is appropriate.
    Dave
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Incidentally, the representation of the transistor in the diagram is a valid symbol for a nMOSFET, where the arrow denotes the source. Switch the arrow direction and you have a pMOSFET. It is a more common representation here in UK.
    Dave
  11. trappy
    Mar 27, 2008
    7
    guys you have been a BIG help to me , thankyou for your time
