Finding the proper Resistor Wattage
Discussion in 'General Electronics Chat' started by vladthegreat1, Jan 6, 2015.
  1. vladthegreat1
    Dec 26, 2014
    26
    Hey Folks So currently have a LED strip that consists of 2 LEDs with 2 resistors in this exact layout
    I have the choice to use 2 types of resistors (this is an SMD circuit if that matters)
    The circuit originally was 2 LEDs that had 2 SMD Resistors marked 151 * upon looking that up i found they were 150ohm resistors 5% . Now i have 2 types of resistors i can put on this board they are:
    150R 150ohm 151 +/-5% 1/10W RoHs
    150R 150ohm 151 +/-5% 1/8W RoHs
    My question is what wattage do i really need for my resistors?
    The specs for the LED's are Forward voltage of between 2.1-3.4 with forward current at 30.
    I do not know why this layout is this way, it was made by an actual company i am just modifying it and trying to make sure I get the correct resistor in there. Please let me know.
  2. #12
    Nov 30, 2010
    16,665
    7,310
    What is the battery voltage and what is the actual LED voltage?
    I come up with 14.6V for the battery, and the resistors are .135 watts each, but that's just an approximation. (educated guess)
    vladthegreat1 likes this.
  3. vladthegreat1
    Dec 26, 2014
    26
    Sorry I forgot source voltage is 12.16 on the voltmeter but let's just say 12
  4. #12
    Nov 30, 2010
    16,665
    7,310
    (There is no such thing as a 2.1 volt to 3.4 volt LED)
    This is looking like 21.87 ma with a resistor power of 0.0717 watts each, but I'm just sneaking up on it.
    And while I'm sneaking up on the exact value, it is customary to install resistors with wattage ratings well in excess of the minimum. It makes them last longer.
  5. vladthegreat1
    Dec 26, 2014
    26
    I guess I was asking a general because there is 5 different types of LED I can use for project lowest forward voltage 2.1 (green) highest is white @ 3.4
    But either way from what your saying I should be OK with both 1/8 (0.125w) and 1/10 (0.10w) right?
  6. #12
    Nov 30, 2010
    16,665
    7,310
    Worst case is .1056 watts. Use the 1/8th watt resistors.
  7. vladthegreat1
    Dec 26, 2014
    26
    Awesome thank you so much #12 you gave been a great help :)
  8. #12
    Nov 30, 2010
    16,665
    7,310
    That's what the, "like" button is for.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,759
    Or the tip jar at most bars...
    Sinus23 likes this.
