Finding the element inside a box
Discussion in 'Homework Help' started by indu407, Aug 10, 2009.
  1. indu407
    Aug 10, 2009
    you have given a box, and it contains one element( resistor/inductor/capacitor) with wires connected to both ends of the elements.
    you need to identify whether the given element is resistor/inductor/capacitor. however you can use voltagesource,ammeter and voltmeter.
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Consider what happens at the time when you connect the voltage source to the box. What changes as time continues? What happens when you disconnect the source from the box?
    For a resistor, when you connect a voltage source the governing equation will be V = i*R. Current, i, flows as long as the source is connected.
    From what you know about capacitors and inductors, how does the voltage and current change over these elements when a source is applied?
  3. mik3
    Feb 4, 2008
    4,846
    63
    Can you use an oscilloscope?
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    If it's anything other than a resistor in the box, you will need an AC voltage source of some sort. They you can figure out the reactance (and impedance) by using the AC impedance formula Z=e/i. It MIGHT be possible to use the RC time constant, if it's a large value of capacitance, or the R/L time constant if ther's a large inductor.
    If you apply 120V ac to the terminals and the box explodes, it's probably an electrolytic capacitor inside. :D
    Eric the Practical.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    I guess this question is somewhat hypothetical. And the question is more related to StayatHomeElectronics answer. How does how does the voltage and current change over these elements when a source is applied?
  6. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    It's always a good answer if it make you laugh though. This one did it for me!
