Finding the biasing resistor for MOSFET
Discussion in 'Homework Help' started by wind_blast942, Sep 12, 2010.
  1. wind_blast942
    Sep 7, 2010
    22
    Hi all
    I have to find the Rs of the following P-MOSFET circuit such that my Id = 0.2mA. Vth and Kp are given.
    I can assume that the transistor is operating in the saturation region. However i realised that there are 2 different methods in solving this and not sure which of it is correct.
    Method 1:
    Assume saturation, via Id = kp(Vgs - Vth)^2, find Vgs.
    Setting Vds = Vgs - Vth (assumption for saturation), find Vds
    Finally getting Rs = (Vdd - Vds - IdRd)/Id.
    Method 2:
    Realise at DC, Cin causes no current to flow through R2.
    Assume saturation, find vgs using the formula in method 1.
    Since there is no voltage drop across R2, Rs = (Vdd - Vgs)/Id.
    Both methods sound reasonable to me, but since they both give different values, not sure which one is correct.
    Please help.
    Thanks.
  2. Ghar
    Mar 8, 2010
    655
    72
    Your assumption of Vds = Vgs - Vth is wrong, saturation is when Vds > Vgs - Vth
    It's only equal at the exact border between saturation and triode.
    You have everything else correct:
    If there's no current in R2 then Vg = 0.
    If Id = 0.2mA then you can find Vgs, and since you know Vg you can find Vs.
    Both of these equations are correct:
  3. wind_blast942
    Sep 7, 2010
    22
    Thanks for the clarification. Just one more thing, when u mean triode are u referring to the linear region?
  4. Ghar
    Mar 8, 2010
    655
    72
    Yes, it's just another name for it.
    The names do get mixed up quite a lot... saturation is the linear amplification range, triode is the linear resistance region, in a BJT saturation is the resistance region while active is the amplification one... always need to stay on your toes as to what someone is talking about!
