Finding resistance in coils
Discussion in 'General Electronics Chat' started by crazybuoy, Aug 7, 2016.
  1. crazybuoy
    Thread Starter Active Member
    Sep 19, 2010
    62
    There is set of coils in 2 different way (Fig 1 & 2). For example, the resistance of one coil is 3 Ohm as shown in image. Please tell me the resistance in following way:
    Resistance between 1 & 2 in Fig 1 - ??
    Resistance between 1 & 3 in Fig 1 - ??
    Resistance between 1 & 2 in Fig 2 - ??
    Resistance between 1 & 3 in Fig 2 - ??
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    If this is a Homework or examination question, post your best effort at answering.
  3. SLK001
    Nov 29, 2011
    852
    243
    Try using simultaneous equations to solve your problem.
  4. crazybuoy
    Sep 19, 2010
    62
    It is not a homework or exam question. I have a stepper motor, I just want to know its winding setting. Please tell me the above resistances.
  5. AlbertHall
    Jun 4, 2014
    2,290
    451
    Resistance between 1 & 2 in Fig 1 - 6 Ohms
    Resistance between 1 & 3 in Fig 1 - 6 Ohms
    Resistance between 1 & 2 in Fig 2 - 2.4 Ohms
    Resistance between 1 & 3 in Fig 2 - 3.6 Ohms
    Edit: Assuming the other pins are not connected
  6. crazybuoy
    Sep 19, 2010
    62
    Yes, all points (pins) in both figures are open. Please tell me how you calculate resistance in Fig-2?
  7. blocco a spirale
    Jun 18, 2008
    1,463
    372
    What is the make and model of this "stepper motor";)?
  8. AlbertHall
    Jun 4, 2014
    2,290
    451
    Fig 2, pins 1 to 2 looks like this:
    Some simple series and parallel resistor calculations give the resistance between 1 and 2. You can do a similar diagram and calculations for 1 to 3.
