Finding R3's value in a parallel when i have R1 R2 R4 and Rt, and I3
Discussion in 'Homework Help' started by Copenhagen, Nov 17, 2015.
  1. Copenhagen
    Nov 15, 2015
    7
    My problem is R1=16 R2=10 R3=? R4=20 Rt=3.582 I3=3.2A
    Now I did the 1/R1 + 1/R2 etc
    which gets me to .2125, so I did 1/.2125
    that leads me to... 4.705882353 for an Rt, that excludes R3's resistance.... I think?
    I cant figure out how to use that to calculate my R3...
    I also did 1/Rt which equaled .279173, I imagine that might be necessary to find R3?
    The answers are in the back of the book so I know what R3 should be, but without knowing how to get there, it does me no good haha.
    This is my first post, I did try searching and didn't really find what I was looking for... Thanks for any help on this issue, great site you guys got going here, Im sure Ill be on here quite a bit throughout my apprenticeship. Hopefully I'll be able to contribute to someone else's question one of these days.
  2. shteii01
    Feb 19, 2010
    3,515
    515
    "picture is worth a thousand words"
  3. Copenhagen
    Nov 15, 2015
    7
    E1_____E2________E3________ E4________ Et________
    I1_______I2________I3= 3.2A____I4_________It_______
    R1=16___R2=10____R3________R4=20______Rt=3.582
    P1 ______P2 ______P3________P4_________P5
    That's the problem in the book, once I get R3 the rest is easy...
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Do you have any circuit diagram for this problem ? The name of the book and the page number?
  5. Copenhagen
    Nov 15, 2015
    7
    No diagram, just the chart and fill in the blanks.
    Book is Delmars Standard Textbook of Electricity, Sixth Edition, Page 171.
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    I think I understated you have four resistors connected in parallel. R1 = 16Ω; R2 = 10Ω; R3 =? R4 = 20Ω and Total resistance is Rt = 3.582Ω.
    So you can use the equation for Rt and solve it for R3. Can you do that?
  7. Copenhagen
    Nov 15, 2015
    7
    I tried using 1/R1 + 1/R2 + 1/R4 + 1/Rt then putting 1 over the sum of that, and it didn't work.
    but I wonder if I do that above, but minus the 1/Rt instead of add it... hmm
    Sorry if im hard to understand... im trying to explain it the best I can from what im looking at, but its not translating all that great apparently lol.
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Here you have a tip:
    Let R1 = 20Ω and R2 = ?? and Rt = 5Ω
    1/Rt = 1/R1 + 1/R2
    1/5Ω = 1/20Ω + 1/R2
    0.2S = 0.05S + 1/R2
    1/R2 = 0.2S - 0.05S ( S -- >electrical conductance, measured in Siemens)
    1/R2 = 0.15S
    R2 = 1/0.15S = 6.67Ω
  9. Copenhagen
    Nov 15, 2015
    7
    1/16 + 1/10 + 1/20 - 1/3.582
    .0625 + .1 + .05 = .2125 - .279 equals -.0665
    1/-.0665 = -15.03759398 Which is close to what I need for R3 according to the back of the book. (15ohms) Except My answer is one the wrong side of Zero...
    But Im not sure if that is the correct way to do it, or I just lucked into it.
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Check your math. You cannot get the negative number.
  11. Copenhagen
    Nov 15, 2015
    7
    A co worker just figured it out...
    1/16 + 1/10 + 1/x + 1/20 = 1/3.582
    .2791 -.0625 - .1 - .05 = 1/x
    1/.0666 = 15
    R3=15
    Thx for the replies. Sorry I couldn't explain it better.
  12. Thomas KF6BSL
    Nov 11, 2015
    R1+R2+R3+R4 = Rt
    1/16+1/10+1/?+1/20 = 3.582
    1/16 = 8/2
    1/10= 5/2 You need to find the Least common denominator, Basic Math.
    1/20= 10/2
    = 23/2 = 11.5Ω
    3.582 However this does not work. In the question do they use this 3.582Ω or this 3.582KΩ or this 3.582MΩ?
    Thomas
    KF6BSL Extra Class Ham License
  13. Thomas KF6BSL
    Nov 11, 2015
    You need to do the remaining part of the equation, For a parallel circuit the total resistance is equal to
    R1 * R2 * R3 * R4
    Rt = R1 + R2 + R3 + R4 I think this is Correct
    What I put above in my earlier post is even wrong.
    Thomas
  14. Copenhagen
    Nov 15, 2015
    7
    Got it figured man, but thank you... The post above yours is what I used to find R3 which was 15ohms.
