Finding power factor using pspice
Abdul Wali
Joined Mar 19, 2016
35
hi i am working on a project and i want to test the power factor of different loads in a circuit so can anyone help me that how to find power factor of a circuit or a load in pspice ?
WBahn
Joined Mar 31, 2012
30,045
It's been a while since I've played with the math functions, but you should be able to implement math functions that integrate the real power pretty easily and those would work for any waveform. You get the apparent power by first measuring the RMS current and voltage and then multiplying them together. Then use the definition of power factor as being the ratio between real power and apparent power.
Abdul Wali
Joined Mar 19, 2016
35
