Finding PIC16F84 in Eagle
Discussion in 'General Electronics Chat' started by Thediabloman, Apr 8, 2008.
  1. Thediabloman
    Mar 11, 2008
    16
    How the hell do I find the PIC16F84 in Eagle?
    It´s driving me mad that I can´t find it.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the device is not in the components library, you may need to create it. I think the help file has a section on creating new parts/components.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    It's in the Microchip library under 16F8*. At least in my version 3.14 it is. Let us know if you still can't find it and I will work out a way to send it to you. John
  4. Thediabloman
    Mar 11, 2008
    16
    I found it.. :)
    But then I found that Eagle is a crappy program.. I only have limited space to draw on, and thats not nearly enough.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    That's a pretty hasty conclusion for a first-time user. When you find something better that is free, please let us know.
    John
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Space limitations apply only to the free version of Eagle. The full version has no such limitation.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can do a lot even with the small board space allowed in the freeware version.
    If you find you're in need of more space, you can always use a dual-row header, and link to another board via a ribbon cable connector. If you do that, I suggest alternating signal/ground/signal etc. to avoid crosstalk.
    In the freeware version, you'd have to split up your schematic into different files. The registered version supports multiple pages for schematics, but not the freeware version.
  8. raffter
    Feb 28, 2008
    113
    Thediablo,
    find a "Crack" for the --crappy-- EAGLEcad you have....
