finding frequency with angular velocity
Discussion in 'Homework Help' started by Hawkeye87, Oct 30, 2008.
  1. Hawkeye87
    Thread Starter Active Member
    Oct 7, 2008
    52
    I just have a quick question on some problems i have.
    The question that i was given was to find the frequency with each given angular velocity...
    A) 60 rads/s
    B) 360 rads/s
    The equation that i saw that i could use is ω=2∏f ...solving for f i get
    f=(ω/2∏)
    Do i have to convert the radians to degrees before putting them into the equation or leave them as is?
  2. mentaaal
    Oct 17, 2005
    451
    you need to have it in rads/second.
    I suppose you could have it in degrees/second but then the formula would be 360*f not 2*pi*f
    A kind soul pointed out my typo so i fixed it :)
  3. Ratch
    Mar 20, 2007
    1,068
    Hawkeye87,
    If you are given the angular velocity in radians/sec, then divide by 2*PI to get hertz. If you are given the angular velocity in degrees/sec, then divide 360 to get hertz.
    Ratch
