Finding equivalent resistance
Discussion in 'Homework Help' started by Mayank Sinha, Jun 16, 2013.
  1. Mayank Sinha
    Jun 12, 2013
    how to find equivalent resistance across A & B if each wire is of resistance 'r' and it continues to infinity in all direction...?????
    plzzz help me out??????????????
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    A commonly used technique in such problems is to consider the effect of the superposition of two equal magnitude currents I [usually 1Amp], one of which is injected (say) into node A and the other extracted from node B - with A and B being separated by a single resistor branch [i.e. adjacent]. Each injected (or extracted) node current is presumed to divide (or combine) symmetrically according to the number of branches at its respective node. The implicit assumption is that the injected or extracted current fans out symmetrically from the node by virtue of the network extremities (albeit at infinity) being held everywhere at a uniform potential with respect to the injection node [A] in one case or the extraction node in the other case. The superposition of the respective injected & extracted currents [in fact their summation] in the linking branch, leads one to a potential difference [VAB] across the resistor branch connecting node A & node B. Viewed as a lumped equivalent the effective resistance is RAB=VAB [Volts]/I [Amp].
    The solution for the case of non-adjacent nodes is rather more complicated.
  3. lava_123
    Jun 15, 2013
    24
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
  5. Andreas
    Jan 26, 2009
    68
    You don't need to know anything these days so long as you know where to look for the answer. I recall this line being a signature from one of the Senior AAC members / moderators. It rings very true. That's the beauty of the internet...apparently (TIC).
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Isn't it great! Raising a generation who can't think for themselves.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    Duly noting the (TIC) annotation, BTW.
    I've seen people whip out their smart phones just before a lab to find out who the two famous actors where that kissed in some scene of some sitcom, but then those same people can't figure out how to find out what the red-red-orange-gold bands on a resistor mean despite the fact that it was in the book, in the lab handout, on a poster on the wall less than ten feet from them, on the course website, and on probably several million websites easily reachable from their smart phone!
    "Idiocracy" is a documentary-in-waiting.
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It is positively scary.
    The humans are getting dumber by the day and the machines much smarter...
    There can only be one possible outcome.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    And it's becoming harder and harder for the people that want to learn to do so because the courses and labs are constantly being dumbed down so now its not a matter of pushing a bit beyond what you are formally exposed to, but needing to take it upon yourself to go WAY beyond. The further out you have to go, the fewer people there are that will have the desire, motivation, determination, and discipline to do so.
    Jaime Escalante: Students will rise to the level of your expectations.
    Wbahn: And usually no further.
  10. Mayank Sinha
    Jun 12, 2013
    thanx to all who help me out especially t_n_k
