Finding datasheets for hard to find parts
Discussion in 'General Electronics Chat' started by Lectraplayer, Jul 11, 2015.
  1. Lectraplayer
    Jan 2, 2015
    77
    5
    I may be missing something, but shown is a salvage part that is beating Professor Google...
    What the heck is this device? Where do I find a datasheet on this?
    Also, is there a tool to help visually ID parts that is similar to Goggles?
  2. Aleph(0)
    Member
    Mar 14, 2015
    358
    347
    That is rohm product in family series like periphiral driver
    DickCappels likes this.
  3. ISB123
    May 21, 2014
    1,240
    531
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Or an LED driver.. It looks like ROHM alright but either customer-specific, custom or something else. It looks like Rohm assigned PNs in sequence without regard to what the actual part was..
    If its just a salvage part, toss it.
  5. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
  6. Lectraplayer
    Jan 2, 2015
    77
    5
    The multi-resistors I have seen have had more of a plastic dipped look. A TV amp IC I had at one time looked like this, but with a metal fin. I still think it's some type of IC. It come out of a failed battery charger, so I'm thinking it was implemented as a charge controller.
    Still, a datasheet would be indespensible.
    I do remember seeing 5-LED indicators shotgunned all around this part number.
    Would Milwaukee Tool have used an LED controller as a charge controller for a screwdriver battery?
  7. Lestraveled
    May 19, 2014
    1,957
    1,218
    I agree with Max, it looks like a resistor array. Have you taken an ohm meter to it?
  8. Lectraplayer
    Jan 2, 2015
    77
    5
    I have not yet, but soon will.
    Back to my original question: this isn't the only questionable component I have. I also have a couple transistor-like devices I would like to identify. With a part number like this, how would I narrow down what I have besides just discovering the datasheet drawing isn't what I'm holding?
  9. Lestraveled
    May 19, 2014
    1,957
    1,218
    Obsolescence and technology move at the same speed, and lately that means fast. All of us have your problem. We all have parts boxes of great parts that are obsolete. Good luck.
  10. Lectraplayer
    Jan 2, 2015
    77
    5
    I would figure it would be no trouble to maintain the datasheet, even if the part is discontinued. It would help techs out to be able to identify the part below as well.
  11. GopherT
    Nov 23, 2012
    6,332
    4,082
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    It's not a resistor array. The 6104 is a 5-segment LED level meter driver with a linear scale, the 6109 is a bidirectional DC motor driver. Clearly the 61xx line is intended for various consumer electronics products. The part in the post #1 photo was removed from something. What?
    The 6105 could complement the 6104 with a log or VU scale, like National's 3914 and 3915, or have a proprietary scale.
    ak
  13. debe
    Sep 21, 2010
    955
    185
    Your 13007 is a FJPF13007, 400v 8amp NPN transistor. Very common in mains SMPS. It would be a lot more helpful to post good clear pictures of both sides of the circuit board.
  14. KeepItSimpleStupid
    Mar 4, 2014
    1,296
    225
  15. debe
    Sep 21, 2010
    955
    185
    Found what you are looking for, its a 5 LED level IC. BA6105.1.png BA6105.2.png
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  17. debe
    Sep 21, 2010
    955
    185
    This is the same looking chip as a motor controller from a VCR loading motor. LOAD MOTOR IC.1.JPG LOAD MOTOR IC.2.JPG
  18. AnalogKid
    Aug 1, 2013
    4,709
    1,301
    "Same looking" and "same" aren't the same. If the part on the motor board is a 6104, then ok. But I suspect that it is a 6109.
    ak
