Finding Damping Factor, Circuits Stability etc.
Discussion in 'Homework Help' started by ltkenbo, Feb 3, 2010.
  1. ltkenbo
    Thread Starter Active Member
    Sep 11, 2008
    30
    So I am in circuits II class and we are learning about analyzing RLC circuits using Laplace Transforms and then using that to find circuit stability, damping factor (zeta).... I understand how to find this using the form:
    s^2 + 2ζωs + ω^2
    from the denominator of a function, however I don't understand when analyzing a circuit, which variable to solve for.
    Like in this problem: http://www.4shared.com/file/214385515/2c766263/RLGCpara.html?
    It was easy, after finding V(s), I just analyzed the denominator using the above form to find zeta and omega.
    However, in this problem:
    http://www.4shared.com/file/214385509/3cdb1f09/DampSelect.html?
    We are asked to find a value basically of a dependent current source that will provide several different ranges. Here I don't know where to start. Like sure I can write some equations, but which one do I use to analyze for zeta?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It's a fairly simple matter to upload pdf files direct to the AAC site. Trying to access your images through the links supplied in your post is an unnecessarily laborious task.
