Finding current
Discussion in 'Homework Help' started by softeng, Mar 25, 2012.
  1. softeng
    Mar 24, 2012
    Once again I can't figure out how to get the answer for this circuit, is i=1A or is the answer I'm referencing wrong.
    (I got 140V after finding R equivalent)
    http://i.imgur.com/cPzBS.jpg
  2. debjit625
    Apr 17, 2010
    790
    186
    Yes "I" the current through the 10 Ohms resistors will be 1Amp.
    Here is a simplified version of your diagram,so that you get a clear picture
    Good luck
    mlog and softeng like this.
  3. softeng
    Mar 24, 2012
    Thanks, solved it :)
  4. mlog
    Member
    Feb 11, 2012
    276
    36
    With the redrawn circuit diagram, you can almost solve it by inspection. Kudos to debjit625.
