finding current
phantomvs
Joined Jan 19, 2016
39
I am stuck on this question, that asks me the following :
If R2 is short circuited , the amps in R3 is : ?
Here is what i did :
I redrew circuit without R2. So it becomes a series circuit R1in series with R3
added the resistance. r1 + r3 so 40 +10 = 50
Found the amps so 30v/50 ohm = 0.6 amps
so 0.6 amps times R1 =6 volts on R1 and 30-6 is 24 volts on R3
Since this becomes a series circuit it should be the same current.
What am i doing wrong ?
phantomvs
Joined Jan 19, 2016
39
from what i am reading ,short circuit on R2 automatically makes R3 0 ohms as well.
So pratically removing R3 from circuit.
So 30v/0 ohms is 0 amps
did i get that right ?
WBahn
Joined Mar 31, 2012
30,061
Yes, since shorting R2 also shorts R3. But you need to be careful about saying that it "removes" them from the circuit, since that is basically the mistake you made originally. They are replaced by a wire (the short circuit).
How do you get that 30 V / 0 is 0 amps? What would 30 V / 0.1 Ω be? How about 30 V / 0.000001 Ω? Does that jive with 30 V / 0 Ω being 0 A?
phantomvs
Joined Jan 19, 2016
39
The voltage across R3 is 30 volts.
As if there is a short on R2 , then there is a short on R3
So to find amps in R3 would be 30 v / 0 ohms as no resistance just a straight wire .
Voltage at R3 is 30 volts ?
WBahn
Joined Mar 31, 2012
30,061
No. What is the voltage across a short (or across an ideal piece of wire)?
WBahn
Joined Mar 31, 2012
30,061
None as well ?
As Jony130 already mentioned, consider the case when instead of a dead short (0 Ω) it is just a very low valued resistance such as 1 Ω, or 0.1 Ω, or 0.001 Ω.
Another way to come at it is to ask how much voltage is across R1 and, as a result, how much current is flowing in R1. Where does that current go? How does it get over to the other side (which, presumably, is at 0 V)?
phantomvs
Joined Jan 19, 2016
39
So since it would be only 1 resistor left as the other 2 become short circuited would it be 3 amps .
Voltage on R1 30 volts
If not i am really lost now :)
