Hi again,
Wbahn:
Oh ok that looks good.
cdummie:
Did you think about what happens when an impedance is in series with a constant current source yet?
That helps a lot too with this circuit.
So that means that i can remove Ig1 from this circuit? If that's true, i don't know how it can help me since i knwo the value of Ig1 and removing it would not mean that i got rid of unknown value.It just circulates current in that upper-left loop and has no interaction with the rest of the circuit. So it can be removed.
When impedance is in series with current source, it means that current through that impedance is the current of that current source.
It doesn't help directly with getting rid of the unknown variable -- but isn't simplifying the circuit and having one less mesh to deal with worth something?So that means that i can remove Ig1 from this circuit? If that's true, i don't know how it can help me since i knwo the value of Ig1 and removing it would not mean that i got rid of unknown value.
And, just like a voltage source that is in series with a current source, what does this suggest that you can do with that impedance?When impedance is in series with current source, it means that current through that impedance is the current of that current source.
Hi again,
Yes, very good, i am happy to see you understand this
Now what does that mean with regard to the only capacitor in this circuit? Answering that question will help simplify the circuit even more, and so little by little the circuit gets more and more simplified. You probably want to draw the circuit again after considering this little fact.
Well, that's right, smaller circuit means less equations.It doesn't help directly with getting rid of the unknown variable -- but isn't simplifying the circuit and having one less mesh to deal with worth something?
I am not really sure what are you trying to say.And, just like a voltage source that is in series with a current source, what does this suggest that you can do with that impedance?
Does that means that i could remove the branch with capacitor? If that is true, why i can't do that when i have resitor in series with current source and capacitor, and what would happen if there was voltage source instead of current source in this case?A sinusoidal source with constant magnitude, frequency, and phase is considered a constant source in AC steady state. Consider that you model it as a phasor whose value is a constant.
When there is an impedance in series with a current source the value does not matter. For example, if we have a 1 ohm resistor in series with a 2 amp current source the current though the resistor is 2 amps, and if we have a 100 ohm resistor in series with a 2 amp current source then the current through the resistor is still 2 amps. The current affects the rest of the circuit, but only affects the voltage at the point between the current source and the resistor. Since only the current matters and not the voltage at the center node, might as well make that resistance the most convenient value that helps to solve the REST of the circuit (not that one node though), and that value is zero. So we short out the impedance.Does that means that i could remove the branch with capacitor? If that is true, why i can't do that when i have resitor in series with current source and capacitor, and what would happen if there was voltage source instead of current source in this case?
You can't remove the branch, but you can remove the impedance that is in series with the current source since, like the case of the series element being a voltage source, the current source will produce whatever voltage is necessary to cancel out the voltage developed across the impedance. A current source masks the voltage of components that are in series with it.
If it's a voltage source instead of a current source, this doesn't apply. But a voltage source masks the currents of components that are in parallel with it.
Have you thought of transforming E2,R2 into an equivalent current source and parallel resistance?
When you say that we cannot solve that one node, you mean the voltage of that one node not the current, since we can't find correct voltage of that node since we changed the value of impedance, but everything else will remain the same as in the original circuit.Hi again,
I haven't ignored it, i tried it and i still had Ig2 in final result, so i thought that i could try different approach, anyway, what is wrong with approach in my previous post?Why are you ignoring post #36? I showed your two equations with minor errors corrected and told you that if you solve those two simultaneous equations you will get the correct answer.
The answer you have obtained in post #38 is not correct.
by Duane Benson
by Duane Benson
by Jake Hertz
by Jake Hertz
