finding base of quadratic system
Discussion in 'Homework Help' started by bhuvanesh, Jul 15, 2014.
  1. bhuvanesh
    Aug 10, 2013
    268
    The roots of the quadratic equation x^2-12x+37=0 are 5 and 8. Find the base system in which this equation is written
    If the roots are 5 and 8, then the equation can be written as
    (((x^2 -(5+8)x + (5*8) = 0}}}
    so in what base is 5+8 = 12 and 5*8 = 37?
    The base must be greater that 8 since one of the solutions is 8.
    The base is greater than 10 since 5*8 base 10 is 40 and our product is 37
    Try 11. Hey, it works!
    5+8 base 11 = 12 and (5*8) base 11 = 37.
    How they say the base should be greater than 8 and also than 10..thank you in advance
  2. shteii01
    Feb 19, 2010
    3,500
    511
    I got different roots.
  3. djsfantasi
    Apr 11, 2010
    2,905
    878
    Since one of the roots is 8, the base must be greater than 8. What if the base were less than 8? Then there is no digit 8! A value of decimal 8 in base 8 would be 10!
    Similar logic can be applied for saying that the base must be greater than 10. 5*8=40 in base 10. But the result is 37. If the base were 10 or less, the result is 40 or more. What is 40 base 10 in base 9? (44) See the direction the digits are going?
    It can be proved mathematically, but observation satisfied me.
  4. PsySc0rpi0n
    Mar 4, 2014
    1,191
    So does WolframAlpha.
    It finds imaginary roots!
  5. djsfantasi
    Apr 11, 2010
    2,905
    878
    Shteii01 and PsySc0rpi0n:
    Are you finding the decimal roots? Note the problem states that the numbers are represented in a base other than base 10? Using base 11 numbers, 5 and 8 are the roots of the equation.
  6. PsySc0rpi0n
    Mar 4, 2014
    1,191
    I see... But that's not what the OP seems to say in the statment above... Even though, is it or is it not important that real roots are, in fact, not real but imaginary roots?
  7. shteii01
    Feb 19, 2010
    3,500
    511
    Ah. I see what you are saying. The roots 5 and 8 are given to the OP.
