Finding a Unknown Inductor Equation
trav
Joined Dec 8, 2011
7
Well I've got the formula F = 1 / 2pi sqrt L x C
and need rearrange to find L but dont really know if my answer is correct.
thatoneguy
Joined Feb 19, 2009
6,359
Is this for a simple, air core inductor with a single winding?
Or to determine the Fo of an LC circuit?
I see both your formulas have f and C in your equations. I must admit I do not understand the question you are asking.
There is a formula for a wound air coil of Length L and diameter d with a winding density factor.
There is a formula for an inductor wound on a ferrite core, but the permiability of the core would be needed.
The resonant frequency, \(F_o=\frac{1}{2 \pi sqrt{L C}}\)
Please be more verbose with your question, explaining what you do know, and what you'd like to figure out.
First, keep in mind: \(\omega=2\pi F\) and \(F=\frac{\omega}{2\pi}\)
--ETA: Your Post #3 states you want to solve \(F_o=\frac{1}{2 \pi sqrt{L C}\)
The equation is derived from:
\(\omega=sqrt{\frac{1}{LC}\)
to get L out, we need to square both sides:
\(\omega^2=\frac{1}{LC}\)
now we can "swap" the left with the denominator
\(LC=\frac{1}{\omega^2}\)
woops, moved one too many:
\(L=\frac{1}{\omega^2 C}\)
Obviously, the formula is the same to find C if you know f and L
\(C=\frac{1}{\omega^2 L}\)
debjit625
Joined Apr 17, 2010
790
@trav
I also didn't understood your question...
Anyway to find out inductance for a coil you can use Wheeler's Formula
Inductance (\mu H) = {{0.8(NA)^2} \over {6A + 9B + 10C}}
where
N = number of turns
A = average coil radius
B = coil length
C = coil thickness
Note
All quantities are in inches and the result is in microhenries \((\mu H)\).
Good Luck
Adjuster
Joined Dec 26, 2010
2,148
The OP's problem appears to be stated in terms of the resonant frequency in a tuned circuit, not the coil's construction.
