Can someone move this to a better location if necessary?
I want to hook an analog meter to my Yagi antenna so the meter will max when the antenna is pointed directly at a cell tower.
My idea is to connect the antenna feed points to a Darlington 2 stage amplifier with a resistor to ground then connect a 50ua meter across the resistor. Would this work? Would a simple signal diode in the feed line help? I figure a 9V battery connected to the collector side and a 100 ohm resistor tied from the last emitter to ground. One feed point from the antenna to the base of the first transistor and the other feed point tied to ground.
I have measured the voltage across the antenna feed points and have observed a gradual increase in voltage from 3mv to 8mv as the antenna direction is slowly rotated to be pointing at the tower.
I have diagrams if that would help. I'm just trying to find the direction to the tower and do not care (for this application) what the actual field strength is.
Thanks,
Mike Taylor
Katy TX
Thanks,
Mike Taylor
Katy TX
