Find the voltage gain
Discussion in 'Homework Help' started by ADCapacitor, Mar 5, 2016.
  1. ADCapacitor
    Feb 3, 2016
    42
    β=210, Vt=26mV, Vbe(on)=0.7V
    How to find Vs,
    then find the Voltage gain Vo/Vs ?
    I try to draw the small signal model to solve the problem
    Vth=15*R2/[R1+R2]
    Vth=1.62V
    Rth=R1//R2
    =5.5kΩ
    -Vth+Rth*Ib+Ie*Re+Vbe=0
    Vth=Rth*Ib*(1+β)*Re
    Ib=(Vth-Vbe)/Rth+Re(1+β)
    =8.2μA
    Since
    Re is short in Ac
    Rπ=Vt/Ib
    =3.18k ohm
    Vo=-β*ib*Rc
    How to find Vs,
    then I can get Vo/Vs ?
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
    Why Vo is at emitter ??
  3. shteii01
    Feb 19, 2010
    3,519
    515
    Current amplifier?
    The better question is how resistor has a value of 10 uF. On the other hand that same resistor is behind dc blocking capacitor so it likely does not matter.
    Ok. Question to OP. What text are you using for learning these stuff?
    My textbook has some good examples on these things and explanations for the approximations that can be used to shortcut thought the complicated math.
  4. anhnha
    Apr 19, 2012
    776
    48
    With current amplifier or buffer I think it is better not to include the collector resistor.
  5. shteii01
    Feb 19, 2010
    3,519
    515
    You are most likely right. I assume that we are dealing with textbook exercise, therefore the actual exact function of the circuit does not matter.
  6. ADCapacitor
    Feb 3, 2016
    42
    Thank you
    I make some mistakes when redrawing the circuit diagram
    The resistor with wrong label is the internal resistor of the signal generator.And the value is not given.
    I think this one is better
    [​IMG] [​IMG]
  7. ADCapacitor
    Feb 3, 2016
    42
    I am using the lecture notes for learning these stuff.
    My teacher give us this question for practice
    Which textbook are you using?It sounds good
  8. WBahn
    Mar 31, 2012
    18,096
    4,920
    I'm not at all sure that this is supposed to be a current amplifier. Even if it is, the collector resistor could be there to either put a limit on the current output or to reduce the collector-emitter voltage to something that compensates for the Early effect.
  9. shteii01
    Feb 19, 2010
    3,519
    515
    My textbook was Electronic Circuit Analysis and Design, Second Edition, Donald A. Neamen.
  10. Jony130
    Feb 17, 2009
    3,995
    1,117
    But are you sure about this diagram and that the output is at emitter ?
  11. ADCapacitor
    Feb 3, 2016
    42
    The output should be at collector
  12. Jony130
    Feb 17, 2009
    3,995
    1,117
    So you have a traditional Common Emitter amplifier. And your problem is Vs ?? So first try to draw the "correct" small-signal model.
    An then you will see that if internal resistor of the signal generator Rs = 0Ω Vin = Vs = voltage across rpi.
  13. ADCapacitor
    Feb 3, 2016
    42
    Is that correct?
    Vs=Vin
    Vin=Ib*R1//R2 ?
    Vo=-βIb*Rc
  14. Jony130
    Feb 17, 2009
    3,995
    1,117
    Are you sure that Ib current is flowing through R1||R2 ?? If so, which current is flowing through rpi then?
  15. ADCapacitor
    Feb 3, 2016
    42
    May be this one
    Vs = ib*Rpi ?
  16. Jony130
    Feb 17, 2009
    3,995
    1,117
    Yep, this time you are on the right track.
  17. ADCapacitor
    Feb 3, 2016
    42
    thank you
    I have some further questions
    I found that some examples use this "RTH=0.1(1+β)Re" to find the Rth
    And it sometimes use Rth=R1//R2
    But why?
  18. Jony130
    Feb 17, 2009
    3,995
    1,117
    When we want to find the DC operation point (quiescent current) in order to simplify the calculation we use thevenin's theorem and replace Vcc and voltage divider at the base by his thevenin equivalent. And in this case Rth = R1/R2 and Vth = R2/(R1+R2)
    http://forum.allaboutcircuits.com/threads/transistor-base.81886/#post-585781
    Can you show us the example? Because (1+β)Re is a AC resistance seen from the base terminal when we looking into emitter and if we ignore r'e.
  19. ADCapacitor
    Feb 3, 2016
    42
    Design a bias-stable circuit . Let β = 100 and VBE(on) = 0.7 Vm , Ic=0.7mA, Vce=4V
    this example use Rth=0.1(1+β)Re to find Rth
    Is "Bias-stable" imply that we can use Rth=0.1(1+β)Re to find the Rth?
  20. Jony130
    Feb 17, 2009
    3,995
    1,117
    OK I see. This formula "Rth=0.1(1+β)Re" is a rule of thumb used sometimes by a designer. And this rule means that we must choose R1||R2 < 0.1(1+β)Re for "bias-stable". This rule ensure that our voltage divider voltage is "stiff". Because base current is a load for our voltage divider. And to ensure that our divider voltage do not change much after we loading it we use this "rule of thumb" to select R1 and R2. The slightly different rule of thumb is to choose voltage divider current Id = Vcc/(R1+R2) at least 10 times the base current. So we have:
    R1 = (Vcc - Vb)/(11*Ib)
    R2 = Vb/(10*Ib)
