Find the voltage gain of operational amplifier
Discussion in 'Homework Help' started by ADCapacitor, Mar 25, 2016.
  1. ADCapacitor
    Feb 3, 2016
    42
    Find the voltage gain and Io
    Vi=V+=V-
    I1=(V-)/R1
    I1=0.5mA
    Node V-
    Vi-0/R1+Vi-Va/R2=0
    Va=-50mV
    NodeA
    [Va-V-/R2] + Va-0/R3 + Va-Vb/R4 =0
    Vb=-0.2V
    NodeB
    Vb-Va/R4 + Vb-0/R5 +Vb-VO/R6=0
    Vo=-0.55V
    Av= -Vo/Vi
    =-0.55/50m
    = -11V/V
    Io= Vo/RL
    =-0.55/100
    =-55mA
    thank for the help
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    And Vin is ?? Also there is some thing wrong with your answer because voltage gain cannot be negative.
    Also notice that if Vin = 1V the voltage at V- is also equal to 1V and from there we can find Va using only KVL and KCL
    Va
    = VR1 + VR2 = Vin + IR1*R2 = 1V + (1V/100Ω)*200Ω = 3V.
    Vb = VR3 + VR4 = Va + VR4 = Va + (IR3 + IR2)*R4 = 3V + (3V/200Ω + 1/100Ω)*200Ω = 8V
    And if you use the similarly approach we can find that Vo/Vin = 21V/V
  3. ADCapacitor
    Feb 3, 2016
    42
    Vin is 50mV
    I use KCL in the above calculation
    current goes into the resistor R2 =current out the resistor R3 +R4
    Vin-Va/R2= VA/R3+Va-VB/R4
    But why
    Va = VR1 + VR2 = Vin + IR1*R2 = 1V + (1V/100Ω)*200Ω = 3V.
    and
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    fir Vin = 50mV the voltage at VA node is equal to:
    Voltage drop across R1 + voltage drop across R2 = VA = VR1 + VR2
    Voltage drop across R1 = Vin because V+ = V-
    Voltage drop across R2 = current through R2 resistor times R2 resistance. And the current through R2 is equal to Vin/R1 because R2 is in series with R1. So, the same current must be flowing through these two resistors.
    Therefore VA = VR1 + VR2 = 50mV + 50mV/100Ω *200Ω = 150mV
    And VB node is equal to VR3 + VR4, Also notice that VR3 = VA and VR4 = I*R4 = (IR2 + IR2)*R4 do you agree with this ?
  5. ADCapacitor
    Feb 3, 2016
    42
    sorry, but I still don't understand...
    I find an example which is similar to this question
    short R5
    V+=V-
    0-Vi/R1 + 0-Va/R2=0
    Va=-0.5V
    Then, I follow the same method to find the Va
    Vi-0/R1+Vi-Va/R2=0
    Va=-50mV
    What's problem here?
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    The maths is your problem.
    \frac{Vi}{R1}+\frac{(Vi-Va)}{R2}=0
    Try solve this for Va
    \frac{50mV}{100\Omega}+\frac{(50mV-Va)}{200\Omega}=0
  7. ADCapacitor
    Feb 3, 2016
    42
    Thank you
    I think I forgot the negative sign , lol
    Va sholud be 150mV
    Then I can use the same way to find Vb,=0.4V ,Vo=1.05V
    then I get the Av=21, Io=10.5mA
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Very good, but you still do not have the right answer for Io. I can assure you that Io is not equal to 10.5mA . By Io I mean the op amp output current. 10.5mA is a current that is flowing through R7 resistor.
  9. ADCapacitor
    Feb 3, 2016
    42
    May be Io is equal to I7-I6 ?
    (Io+I6=I7)
    And I6=Vb-Vo/R6
    I know the I6 and I7 ,then I get Io?
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Why you think that Io is a difference between I7 and I6 ?
  11. ADCapacitor
    Feb 3, 2016
    42
    Because Io and the current flowing out the resistor R6 are flowing into node Vo?
    So I guess Io which is equal to I7-16
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    Note that for Vin = 50mV we have Vo = 1.05V and Vb = 0.4V. So in which direction IR6 current is flowing ?
  13. ADCapacitor
    Feb 3, 2016
    42
    Thank you
    I get it
    So Io is Vo/R7 +Vo-Vb/R6 ?
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, that right but also do not forget about parentheses.
    ADCapacitor likes this.
  15. The Electrician
    Oct 9, 2007
    2,301
    338
    You had the same problem with lack of parentheses in post #1. The expressions missing parentheses happen to be such that if they are evaluated left to right without any attention paid to operator precedence, you get the right answer. Some calculators behave this way and perhaps that's what you used when evaluating those expressions, but you may not be lucky enough to have expressions that evaluate properly left to right next time. Better to use parentheses.
    For extra credit, solve the problem for an opamp with a finite gain of 10. :)
