Find the Thevenin’s equivalent circuit
Discussion in 'Homework Help' started by sonutulsiani, Mar 4, 2010.
  1. sonutulsiani
    Jan 27, 2010
    27
    I got V=30. I am confused if R = 4 ohm or 1 ohm?
    I did the same circuit in multisim program and it said R=4 ohm
    But if it's a short circuit won't the 3 ohm parallel to short circuit be 0 ohm?
  2. The Electrician
    Oct 9, 2007
    2,301
    339
    What short circuit are you referring to?
    What 3 ohms are you referring to?
    You need to be more specific.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Electrician,
    I suspect that sonutulsiani is referring to the parallel combination of the 4 ohm and the 12 ohm which yields 3 ohms.
    hgmjr
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    The simulator has yielded the correct answer, in case you were wondering.
    hgmjr
  5. Heavydoody
    Jul 31, 2009
    140
    11
    Did you use nodal analysis to find Vth? If so, when you short the right side terminals you will add one element to your nodal equation (1 ohm resistor) for finding the Isc. I solved it in my head without changing anything in the circuit (other than the imaginary short) and came up with 4 ohms as well.
  6. sonutulsiani
    Jan 27, 2010
    27
    Yes I used nodal analysis
  7. sonutulsiani
    Jan 27, 2010
    27
    But I am asking after combining 12 and 4 ohms which results in 3 ohm resistor.
    So now 3 is parallel to short circuit, which results in 0 after combining both of them? and then R=0+1=1
  8. The Electrician
    Oct 9, 2007
    2,301
    339
    When you're finding Rth, you short the 32V source and the equivalent 3Ω resistor is not in parallel with the shorted 32V source. The shorted 32V source is in series with the 4Ω resistor, and that combination is in parallel with the 12Ω resistor. The shorted 32V source is not in parallel with the 12Ω resistor because the 4Ω resistor is in the way, so to speak.
    When you find Isc, the short is across the a-b terminals, and that short is also not in parallel with the 3Ω equivalent.
  9. sonutulsiani
    Jan 27, 2010
    27
    Ok I short the 32 Vsource and then the 4 ohm and 12 ohm resistors are parallel right?
    Which results in 3 ohm resistor. I am not finding the current, I am trying to find the equivalent Thevenin resistance.
  10. Heavydoody
    Jul 31, 2009
    140
    11
    I think some of the confusion is coming from a difference in method. I have been taught to solve these somewhat differently from the way AAC teaches. But it hasn't failed me yet (not that I have a ton of experience mind).
    While it is clear you need to find an equivalent resistance, not current, you can derive that resistance from a current quite simply. Here is how I solved this.
    As the circuit is drawn, find the single unknown node (where the 4 and twelve ohm resistors meet the 2 amp source). Your node here is actually a surface which extends around the 1 ohm resistor since no current flows out of that resistor. What results from this single equation is Vth.
    Next, short out terminals a and b. Change nothing else in the circuit. Perform nodal analysis again, except now you need to include the 1 ohm resistor in your equation since current does flow through it. The resulting voltage minus your reference (0) divided by 1 ohm is your short circuit current (Isc).
    Finally, divide Vth by Isc and you get Rth and you are done. Pretty simple and straight forward here, no source transformations, no combining resistors, no superposition, yada yada yada.
  11. The Electrician
    Oct 9, 2007
    2,301
    339
    Yes, but they are not then in parallel with a short.
    Replace the 32V source with a wire (a short) and then slide the 4Ω resistor around to the left until it's in the place where the 32V source was.
    Now do you see that there is no short in parallel with the 4 and 12 ohm resistors?
