find the pure reactance...
Discussion in 'Homework Help' started by herbgriffin, Feb 16, 2011.
  1. herbgriffin
    Feb 14, 2011
    11
    a circuit with the unknown X (pure reactance) in sereis with a two parallel impedance.Z1= 4-j8 ; Z2= 1+j10 ....and total power factor is 0.707..
  2. steveb
    Jul 3, 2008
    2,433
    469
    Sounds more like a statement than a question, but I'll assume it's a question and see that you want to find X.
    The first step is to combine the known parallel impedances into one effective impedance Zeff=Reff+jXeff. Then ask what impedances Zt=Reff+Xt can give a power factor of 0.707. Remember that series impedances add and the real and imaginary parts of the impedance are separable and distinct. The unknown X will be Xt-Xeff.
    Try this approach and if you still don't get it, at least post your attempt, which is a rule here. I've already given more information than I should without you posting an attempt, or at least a statement of what you do and don't understand about this problem.
