Find the output of the following logical circuit
Discussion in 'Homework Help' started by Arsalan Shahid, Aug 29, 2016.
  1. Arsalan Shahid
    Aug 29, 2016
    Find the output of the logical circuit, given that logic integrated circuit treats +9V as 1 and <9V as 0.
    I'm unable to figure out what is happening at the left hand side of the circuit.
    Any help will be much appreciated.
    Thanks in advance.
  2. AlbertHall
    Jun 4, 2014
    2,262
    448
    I take it this is homework as this circuit does nothing. Weird!
    As the battery on the left is 6V then anywhere in that resistor network cannot be more than 6V. The three op-amps are wirde as voltage followers, so the outputs also cannot be more than 6V. So those three inputs to the logic network must be less than 6V and so can only be understood as logic '0'.
    Arsalan Shahid likes this.
  3. DickCappels
    Aug 21, 2008
    2,769
    669
    Since the output is binary, you have a 50% chance of getting it right by just guessing.
    To start, can you calculate the voltages at all of the comparator inputs? It should be easy to find the states of their outputs from that.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Are you sure those are 6 Ω and 3 Ω resistors?
    Strictly speaking, it doesn't matter (in light of the issues mentioned by AlbertHall).
