Find the natural response given the step response
Discussion in 'Homework Help' started by tquiva, Apr 4, 2011.
  1. tquiva
    Oct 19, 2010
    176
    Given the following step response of a circuit:
    step(t)= 0, t<-2
    = (t+2)^2, -2<t<0
    = 4, t>0
    (a) Carefully sketch and label the natural response of this circuit.
    I know that step(t) + nat(t) = H(s)
    w/ nat(t) being a special case of the step response (w/ a final value of zero)
    I would have determined nat(t) = H(s) - step(t)
    However, the transfer function wasn't given.
    Is there a way to determine it given just the step response? Or is there another possible way to solve this problem?
    Any help is appreciated. My thanks in advance.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps you might clarify the problem.
    Presumably the response is what you have denoted as "step(t)".
    What is the input step definition, if that is indeed the response?
    Problems in the Laplace domain are normally defined for t>=0, with initial conditions satisfied at t=0, whereas your problem is not.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I'm guessing also that your reference to the natural response would normally be described by the inverse Laplace transform of the transfer function [H(s)], which is is also the time domain unit impulse response.
  4. tquiva
    Oct 19, 2010
    176
    For the unit step input: u(t) = 1 t>=0
    = 0 t<0
    So with ilaplace:
    step(t) + nat(t) = H(t)
    with the given information of the input unit step and step response, how can I find H(s) ?
