Find LED current in switching circuit
Discussion in 'Homework Help' started by ShowerOf, Nov 17, 2009.
  1. ShowerOf
    May 4, 2009
    13
    For the switching circuit shown:
    Vcc = 6V
    Base supply voltage (when ON) is 3.6V
    The LED has a forward voltage drop of 2V
    The transistor has a Vbe = 0.7V
    Question: Calculate the current through the LED when the switch is on.
    My calculations:
    Ve = Vbb - Vbe
    Ve = 3.6 - 0.7
    Ve = 2.9V
    Ie = Ve / Re
    Ie = 2.9 / 180
    Ie = 16.11mA
    So can I assume that current through the LED is approximately equal to Ie ?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, you can assume that Ic=β/(β+1)*Ie
    So Ie≈Ic in active region.
  3. ShowerOf
    May 4, 2009
    13
    To find the power dissipated by the transistor.
    using calculation based on another thread
    http://forum.allaboutcircuits.com/showthread.php?t=7426
    Vc = Vcc - VLED
    Vc = 6 - 2
    Vc = 4V
    Vce = Vc - Ve
    Vce = 4 - 2.9
    Vce = 1.1V
    P = Vce * Ie
    P = 1.1 * 16.11mA
    P = 17.72 mW
    Is this correct ?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, look ok for me.
  5. ShowerOf
    May 4, 2009
    13
    Thank you Jony130, I am grateful to have somewhere to get help and
    get my answers checked.
    Cheers :)
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you have 3.6V on the base of this transistor you will have 16.7ma through the collector. This configuration is a constant current source (BJT excel at those).
    If the power supply were 2V greater you could use any color LED, as it will still be a constant current of 16.7ma.
    Figure 3.6V (base) - 0.6 (BE drop) = 3.0V at the emitter
    3.0V/180Ω = 16.7ma.
