Find I1
Discussion in 'Homework Help' started by matttrix, Mar 11, 2009.
  1. matttrix
    Mar 6, 2009
    11
    Find I1, if R4=2Ω and R2=R3=8Ω
  2. JoeJester
    Apr 26, 2005
    3,402
    1,221
    Can you post your efforts at solving the problem?
  3. matttrix
    Mar 6, 2009
    11
    A 9 ohm, an 18 ohm, and a 6 ohm (2+8||8) are all in parallel with the 3 ohm through which I1 flows. I realize that the 3 ohm (through which I1 flows) is in parallel to this combination of the other three resistors. But from here am lost.
  4. vvkannan
    Aug 9, 2008
    138
    11
    Hello matttrix,
    As you said 18,6 and 9 are parallel and their equivalent combination is 3 ohm.
    By current division rule
    I1 = Is x (3/6)
