Find i with dependent source..
Discussion in 'Homework Help' started by Ammar i, May 14, 2013.
  1. Ammar i
    Feb 7, 2013
    How can I find il in this circuit using phasor concept (Frequency Domain)?
    The problem for me is with the dependent source.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Is it a dpendent current source or a dependent voltage source. The symbol implies it is a voltage source but the controlling equation indicates it is a current source.
    What is the controlling current. The controlling equation says "il" (or possibly "i1"), but I don't see it indicated anywhere on the diagram.
    If this were a DC circuit with just a battery and two resistors, could you solve it?
  3. Ammar i
    Feb 7, 2013
    Yes I can.
    il = current of the inductor.
    the dependent source is a current source.
    sorry for that.
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    Then replace the voltage source with a source called Vs and the inductor with an impedance called Z_L and solve for the the inductor current I_L just as you would a DC circuit. Don't use numerical values for anything, solve it symbolically. Do that and we will take it from there.
