Find Hysteresis
bertus
Joined Apr 5, 2008
22,278
Here is the circuit you posted in the PDF:
I assume the output of the comparator will go to 0 Volts when low and to + 5 Volts (=V2) when high.
The upper switch limit will be when the output is high:
The resistor R5 will be parallel to R2.
The voltage at the input will be 5 * R1 / (R2||R5+R1)
The lower switch limit will be when the output is low:
The resistor R5 will be parallel to R1.
The voltage at the input will be 5 * (R1||R5) / (R2 + (R1||R5))
The hysteresys will be the difference between these values.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,278
The calculations I gave will not work.
The comparator has open drain output, so a resistor to the powersupply is needid.
See datasheet.
This resistor will add to the R5 when the high switch voltage is calculated.
Greetings,
Bertus
hgmjr
Joined Jan 28, 2005
9,027
\(V_{\small{(-H)}}=\Large {{\frac{\frac{5}{20}}{{\frac{1}{20}}+{\frac{1}{1}}+{\frac{1}{68}}}}}\, \normal {=\,0.234807\,Volts}\)
\(V_{\small{(+H)}}=\Large \frac{{\frac{5}{20}}+{\frac{5}{(68+R_{pu})}}} {{\frac{1}{20}}+{\frac{1}{1}}+{\frac{1}{(68+R_{pu})}}}\)
Here are the two Millman's Theorem equations.
Once you choose a value for Rpu, you can plug it into the second equation and solve for the positive hysteresis setpoint.
hgmjr
Wendy
Joined Mar 24, 2008
23,429
To restate what has been said a different way, think in terms of voltage dividers. When the two inputs are at the same voltage, that is when it will switch.
Each leg with 2 resistors will divide the voltages to fixed values, which sets the hysteresis.
