find equivalence resistance....
Discussion in 'Homework Help' started by gaurav1292, Oct 1, 2009.
  1. gaurav1292
    Oct 1, 2009
    12
    calculate d equivalent resistance b/w d terminals of d cell. d resistance of each quadrant 1.e blue one is 1 ohm and that of intersecting diameter i.e green one is 2 ohm.
    i tried by distributing current in various branch but was not successful. plz tell me a way to solve this problem.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I did it by re-drawing the circuit in a clearer format.
    Then I used delta-star transformations to reduce the network to a form where simple series-parallel rules can be applied.
    I calc Rtot seen by source is 2.6471 Ω
  3. syed_husain
    Aug 24, 2009
    61
    5
    hi, tnk,
    i tried to solve with mesh equations. i got the same answer but the problem is it i had to solve 4 equations with 4 unknown. i tried 2 use thevemin but failed. could u pls tell me how did u do delta-Y transform?
    thnx.
  4. Tesla23
    May 10, 2009
    323
    67
    Draw a line of symmetry through it at 45° then the resistance is
    2 * (0.5 + 2||(1 + 2||0.5)) = 45/17 = 2.6471
    where a||b = ab/(a+b) - parallel resistors
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi Syed,
    Tesla123's method is clearly the most elegant and succinct.
    If you are not sure how he did it and/or are still interested in my longer method I have included an attachment.
  6. syed_husain
    Aug 24, 2009
    61
    5
    tesla23 and tnk, thank u very much 4 ur help. i really appreciate it.
    Syed
  7. gaurav1292
    Oct 1, 2009
    12
    thanks for ur help!!!!!!!!!!!
