Filter capacitor with 3 pin voltage regulators
Discussion in 'General Electronics Chat' started by vks_foe, Oct 11, 2010.
  1. vks_foe
    Thread Starter Active Member
    Jan 11, 2009
    55
    5
    Can somebody please tell the purpose of using electrolytic as well as ceramic capacitors both, for filtering at the input and output of 3 pin regulators like 7805 ???
    RRITESH KAKKAR likes this.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The smal capacitors at the in and output of the regulator are there to prevent the regulator from oscillating.
    Bertus
  3. vks_foe
    Jan 11, 2009
    55
    5
    Can you please explain in somewhat more detailed way, that how it prevents oscillations...
    vikash
  4. DonQ
    May 6, 2009
    320
    11
    Electrolytic caps are good for getting lots of uF in a relatively small package, but it comes with a cost. They also have a relatively high built-in inductance. They are very good at low frequencies, where lots of capacitance is needed, but at very high frequencies, the inductance becomes a problem.
    Ceramic caps are generally not so good at getting lots of uF, but they have almost no inductance. At high frequencies only a little capacitance is needed, but any inductance would be a problem.
    Both are needed to filter both low and high frequency components of whatever non-DC components that may be present on the line.
    One large value electrolytic, paralleled with one small value ceramic... win-win.
    vks_foe and RRITESH KAKKAR like this.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    The other half of that equation is regulators are high gain circuits, to quickly respond to load changes. This can lead to oscillation.
  6. vks_foe
    Jan 11, 2009
    55
    5
    Thanx to all !! :)
