filter capacitor for 500 volts bridge output
Discussion in 'The Projects Forum' started by shangrila, Oct 7, 2013.
  1. shangrila
    Nov 14, 2008
    I am working on a power supply of ultrasonic frequency generator.
    For supplying current to Mosfet I am using step up transformer (220v step-up to 500v @ 2amp). What would be the capacitor value for filtering the ripples out of bridge. I am having two big size capacitors of 10,000 microfarad (250V) each and intended to use in series; will it work…
    Thanks in advance for any help/suggestion.
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Depends on the peak current of the bridge. You could end up blowing the bridge.
    Don't operate a component at 500V if it is rated at 500V.
    Choose lower sized capacitors wired in parallel but rated at 750V.
    shangrila likes this.
