Filter approx output given input
Discussion in 'General Electronics Chat' started by johnd909, Mar 13, 2016.
  1. johnd909
    Mar 13, 2016
    Given the input Filter function, u = sin(2 π [50Hz] t) + sin(2π{50000Hz} t)
    What is the approx output?
    At a first glance I think the output is 0 DB.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm not sure what a filter function refers to. To measure something using dB you have to compare two things. If they are the same then 0 dB is the way to describe that relationship.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,695
    1,297
    If you are asking what the attenuation of the filter is, we kinda sorta NEED the frequency of interest.
    ak
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    When I think of a time-domain "filter function" I think of the impulse response of the filter. If that's what you mean, then you are describing a filter that, when hit with an impulse, rings at two perfect frequencies with no transient. That doesn't make sense.
    Please describe what YOU mean by "filter function" more explicitly -- it might just be a matter of different terminology.
  5. crutschow
    Mar 14, 2008
    13,498
    3,374
    0dB is the attenuation of a solid piece of zero resistance wire. ;)
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Although stranded zero resistance wire can come pretty close. :D
